christopherius
- Mazda 2 Touring 2011
What are your thoughts on oil filter brands? I am currently using ACDelco filters as they are what we use at my workplace. Are the Mazda filters a better choice?
WIX has been in all my Mazdas since Day1.
Not all oil filters are the same..not by a longshot. This is pretty enlightening:
http://www.gmtruckcentral.com/articles/oilfilterstudy.html
Holy cow that's a great link. I haven't seen any oil filter comparisons that had controlled conditions like that before, thanks for sharing!
The only problem I see is they don't test how much crud they will filter out before they clog up and go into by-pass mode(which would then filter nothing at all). If you're filtering out every single little .0000001" particle, it will clog up sooner as you have a fixed amount of space to take up inside an OEM size filter housing. This really won't matter unless you're trying to go for extended oil change intervals(like 10k+ maybe?). Not sure. Send off for a used oil analysis to know for sure. I'm planning on sending mine off at the next oil change probably in a couple months just to make sure nothing is wrong with my Pureone filter + 0w20 Pennzoil Platinum. If there are no red flags I'll just keep using it.
I use either Wix (expensive as ****) or the Purolator filter that they sell at walmart, I belive it used to be the Supertech brand. Is the purolator at walmart the same as the pureone? I never actually paid attention. Anyways, I change out my oil/filter every 5k miles and so far so good. I don't think you really need to over think the filter. Just use one made by a reputable brand and at proper intervals and you should be fine.
Question though, do you guys change your oil at 5k or 7,500? Im wanting to extend out to 7,500 to save a little money in the long term, but not at the expense of shorter engine life. I believe the filter will probably go bad before the oil. I of course use mobil1 0w20.
So what is the purpose of an anti bypass valve?
I can't say I've ever had the oil drain back out of the filter and into the pan. When I do oil changes, the old filter is full when I spin it off.
