Oil Change
Hyun
Banned
Went to dealer and they said oil change for speed 3 and 6 are more expensive then other mazda models.(dunno)
My MS3 manual says 5 quarts.
Not to be a stickler, but 6 quarts sounds like overfilling to me. The VW dealership I used to have my (don't have it anymore) 04 GTI serviced at routinely added too much oil. So, now I do it @ my local garage..
Isn't Sythetic oil required for Turbo cars?
I seriously doubt a 4 Cylinder would ever use 6 quarts. My V8 uses 6.
I don't think it's necessary. However, I do plan to run synthetic in my MS3 from 3000 miles on.
1st oil change @ 150 miles, second scheduled for 1500 miles, both conventional oil. Then I'll make the switch.
my manual says 6 quarts. with filter change.
sometimes without filter change manuals will say almost a quart less.
more oil, if it has a pan to handle it. plus whats runngi in thelines for hte turbo. more fluid longer to get fully dirty, (might be kinda why the manual says 5000 miles for change) and longer to heat up. maybee.
if you look at soem dealers like ford with a service plan. service plan for my dads truck is every 5000 miles. for his buddy wth no service contract its every 3000 miles. and they said it was becasue m dad had the free service plan it was longer
And i think someone said they emailed mazda about synthetic oil. and mazda does nto recomend. probably cause they havent tried it. but they dont!
