Official: 2006 Subaru Impreza WRX STi (info & specs for America)
mikeyb
Contributor
01 BMW 325xi Touring
<TABLE cellSpacing=0 cellPadding=0 width="90%" align=center><TBODY><TR><TD>Quote </TD></TR><TR><TD class=quote>
SUBARU IMPREZA WRX STI RESTYLED FOR 2006
300-hp Supercar Gains AWD Enhancement and New Safety Technology
CHERRY HILL, N.J., July 21, 2005 Subaru of America, Inc., Americas all-wheel drive leader, has restyled its Impreza line for 2006 and in addition given the all-conquering 300-horsepower WRX STI model several performance enhancements. On the safety front, all Impreza models gain the new dualstage Subaru Advanced Airbag System.
Following an interior redesign for 2005, all Impreza models have been restyled for 2006 to reflect the new brand identity. The new Subaru signature front-end design for Impreza features a three-section mesh-type grill inspired by the companys aircraft heritage, plus boldly styled headlights with smoke-tinted lenses.
All 2006 Impreza models are also identified by a new tail lamp cluster design.
The 2006 WRX STI is also distinguished by the lower-profile hood scoop from the standard WRX to aid forward visibility. Daytime running lights (DRL) are added to the safety roster to make the WRX STI more visible to other drivers. A new roof vane spoiler, inspired by the Impreza World Rally Championship competition car, contributes to stability at track speeds and reinforces the cars highperformance
attitude.
The WRX STI received several significant chassis performance enhancements for 2005, including wider wheels. For 2006, the addition of a steering sensor input to the DCCD All-Wheel Drive system enhances power distribution response by more accurately relaying the cars cornering situation. The WRX STI is based on the Impreza WRX platform but is completely re-engineered to provide even higher levels of acceleration, handling and braking performance that challenge the worlds best sports
cars. In its first year, the WRX STI won Road & Track magazines Best Car 2004 Readers Choice Award, edging out several dedicated(?) sports cars, including the Porsche 911 GT3.
The Impreza WRX STI is powered by a turbocharged and intercooled 2.5-liter DOHC boxer engine producing 300 horsepower at 6,000 rpm and 300 lb-ft. of peak torque at 4,000 rpm. Teamed exclusively to a 6-speed manual transmission, the engine can propel the WRX STI from zero-to-60 mph in under five seconds. Power is transferred to all four wheels by a sophisticated Subaru Symmetrical All-Wheel Drive system with Driver Controlled Center Differential (DCCD) to optimize performance in all conditions.
Rally Tested, Road Ready The WRX STI draws motorsports technology directly from Subaru expertise in World Rally Championship (WRC) competition and is designed to appeal to the most serious driving enthusiasts. STI stands for Subaru Tecnica International, the high-performance and motorsports subsidiary of Fuji Heavy
Industries Ltd.
In its exterior design, Impreza WRX STI leaves no doubts about its performance potential a look that is equally functional. The scoop in the aluminum hood feeds outside air to an intercooler that is significantly larger than the intercooler used on WRX models. The dual-plane rear spoiler which appears to be borrowed directly from the Impreza World Rally Car helps reduce lift and improve stability at track speeds. An aerodynamic underbody cover and the new roof vane spoiler contribute to enhanced high-speed track stability. Airflow is also managed via front side spoilers on the front bumper
and STI-design aerodynamic side ground effects.
The front fascia features a four-beam headlight system with high-intensity discharge (HID) low beams. Distinctive STI fog light insert covers add to the no-nonsense look. Large diameter Brembo brakes are clearly visible between the spokes of the 17-inch lightweight aluminum-alloy BBS wheels.
300-Horsepower Turbo Legend
The 2.5-liter horizontally opposed (Boxer) 4-cylinder engine is based on a specially reinforced semiclosed deck engine block with forged aluminum-alloy pistons, forged high-carbon steel connecting rods and sodium-filled exhaust valves. The Subaru Active Valve Control System (AVCS) variable valve timing technology helps provide strong torque characteristics throughout the engines operating range.
The turbocharger produces 14.5 psi of maximum boost compared to 13.5 in the standard WRX. The large capacity intercooler uses a manually operated water spray feature to enhance intercooler efficiency during high-performance driving.
Symmetrical All-Wheel Drive With Driver Controlled Center Differential (DCCD)
The Impreza WRX STI is equipped with the brands most performance-directed Symmetrical All-Wheel Drive system featuring Driver Control Center Differential (DCCD). A planetary center differential provides a performance-oriented 35 percent front / 65 percent rear power split. Set in automatic mode, the electronically managed continuously variable transfer clutch can vary the torque distribution ratio as
needed to suit driving and road-surface conditions.
Automatic mode provides the best all-around performance for most drivers and circumstances, varying the front/rear torque distribution automatically depending on driving conditions and driver input. The system determines the ideal power distribution in response to vehicle acceleration, deceleration, steering angle, cornering force and wheel slippage.
In manual mode, DCCD allows the driver to vary the front-to-rear torque distribution (up to 50/50 maximum) to optimize All-Wheel Drive performance for varying driving conditions. The driver first selects manual mode with a console-mounted button and then turns a thumbwheel on the center console to select from among six levels of center differential locking. Increasing the lock factor keeps more power at the front wheels, which the driver might want in certain driving conditions, on particular roads or to
suit an individual driving style.
A helical-type limited-slip front differential and mechanical clutch-type limited-slip rear differential help to optimize power distribution side-to-side, helping to ensure that the inside wheels dont slip during cornering.
Competition-Bred Chassis
A super-stiff Ring Frame Reinforced body structure with a hydroformed front subframe provides the foundation for the high-integrity Impreza platform. Compared to the standard WRX models, the WRX STI is lowered by 0.4-inch to help yield a lower center of gravity. The 4-wheel independent suspension inherits technology from the Impreza WRC competition car, but has been strictly optimized in the WRX
STI for high cornering performance on paved roads. Inverted struts used for the front and rear suspension increase bending resistance for quicker and more consistent performance under hard cornering. A rally-derived variation on the MacPherson-type strut, the
inverted strut essentially functions like a conventional shock absorber set upside-down and encased by another tube. The strength of the outer steel tube bears the brunt of bending forces acting upon the strut under cornering, rather than the internal piston rod. The piston rod operates in the lower portion of the strut tube rather than the upper section.
The secondary upper tube mounts to the inner fender where the piston rod would mount in a conventional strut. The pistons stroke remains consistent during hard cornering, helping to maintain the ideal tire-toroad surface contact pattern for increased traction and cornering power.
Aluminum front suspension lower control arms and aluminum rear suspension lateral links reduce unsprung vehicle weight. The standard BBS light-alloy wheels measure 17 x 8-inches and are equipped with 225/45 ZR17 Bridgestone Potenza RE070 directional performance tires.
The quick-ratio steering system yields 2.6 turns lock-to-lock, and the steering rack uses a cannon mount for greater rigidity that improves on-center response. A damper valve helps reduce kickback that the increased rigidity might cause.
Brembo Brakes with Super Sport ABS
Subaru equipped Impreza WRX STI with one of the most advanced and performance-optimized braking systems on the market today. The powerful Brembo Performance Brake System employs ventilated 4-wheel disc brakes to help ensure stopping power and consistency commensurate with the vehicles high performance capability. The front discs measure 12.7 inches in diameter and 1.2-inch thick and utilize 4-piston, fixed-position calipers. The rear discs are 12.3 inches in diameter and 0.8-inch thick and use 2-
A combination of Electronic Brake-force Distribution (EBD) and the Super Sport Anti-lock Braking System (ABS) helps to reduce stopping distances and understeer compared to conventional ABS systems. EBD provides precise control of braking pressure between the front and rear wheels based on the vehicle load to improve stability and stopping distances. Conventional ABS systems control the rear wheels as a pair, reducing the braking force to both rear wheels. Super Sport ABS, using input from a lateral gsensor,
can control the braking forces at each rear wheel independently, optimizing the braking ability during hard cornering to help reduce understeer.
Performance-Directed Interior
The WRX STI conveys its performance attitude from the inside, as well. The driver grips a MOMO 3-spoke leather-wrapped steering wheel. Performance design front seats feature substantial side bolsters, integrated head restraints and embroidered STI logos. The seats are upholstered in unique perforated 2006 Subaru Impreza WRX STI Release / 5 blue high-grip Ecsaine fabric with contrasting black knit bolsters, complemented by matching blue door trim and blue floor carpeting.
The WRX STI instrument gauge cluster places a 9,000-rpm tachometer in the center, flanked by a 160-mph speedometer, DCCD display and fuel and temperature gauges. All three primary gauges feature aluminum trim rings. Red LED indicators and an illuminated STI logo in the tachometer reinforce the sporty driving environment. Previewing the vehicles performance potential, all the gauge needles swing
to their maximum positions when the ignition is switched on, and then return to their normal positions.
The standard automatic climate control system integrates cabin air filtration. The standard 140-watt AM/FM premium stereo plays through six speakers and includes a 6-disc in-dash CD changer. An engine immobilizer security system is standard equipment.
New Safety Technology for 2006 Front seat head/chest side impact air bags (SRS) are standard, and all Impreza models for 2006 get the new Subaru Advanced Frontal Airbag system. The drivers side air bag deploys according to the drivers proximity to the steering wheel, as measured by a sensor on the seat track. In the passenger side front
seat, a sensor module detects weight on the passenger seat first determining if its occupied, and if so by a child or adult to control air bag deployment. As part of the system, the dashboard features a new Airbag indicator light. Front seatbelts integrate electrically triggered pre-tensioners and force limiters. A safety pedal system in all Impreza models is designed to prevent injury to the drivers lower limbs in the event of a serious frontend collision.
</TD></TR></TBODY></TABLE>
Specifications
Body 5-passenger sedan with blister-fender design
Engine Horizontally opposed (boxer), turbocharged/intercooled
Block Specially reinforced die-cast aluminum with integral forged steel cylinder liners, five
main bearings, semi-closed deck cylinder design
Cylinders 4
Displacement 2,457 cc (150 cu. in.)
Bore x Stroke 99.5 x 79 mm (3.92 x 3.11 in.)
Heads/Valvetrain Aluminum alloy cylinder heads with double overhead belt-driven camshafts (DOHC),
four valves per cylinder, Subaru AVCS (Active Valve Control System) variable valve
timing and sodium-filled exhaust valves
Compression ratio 8.2:1
Horsepower 300 @ 6,000 rpm
Torque 300 lb.-ft. @ 4,000 rpm
Fuel/Induction
Aluminum alloy intake manifold, sequential multi-port fuel injection (MFI) with multispray
injectors and Tumble Generator Valves, electronic throttle control (ETC) system,
high-boost turbocharger, intercooler and manually operated intercooler water spray
Max. boost pressure 14.5 psi
Igniton Direct with iridium-tipped sparkplugs
Emission control
system
CA LEV 1 / Fed Bin 10
Low Emission Vehicle (LEV) standard, 50-state certified
Fuel requirement 91 octane minimum
Drivetrain Symmetrical All-Wheel Drive with DCCD (Driver Control Center Differential), helical
limited-slip front differential and mechanical limited-slip rear differential, steering angle
input sensor
Transmission 6-speed manual transmission with cooler
Gear ratios
1
2
3
4
5
6
R
3.636
2.375
1.761
1.346
0.971
0.756
3.545
Final drive 3.90
Chassis Unitized body construction with Ring-Frame Reinforced structure, hydroformed front
subframe and tailored blank-welded side sills and B-pillars
Suspension 4-wheel independent, high-performance sport-tuned
Front MacPherson-type inverted struts with aluminum-alloy lower L-arms and aluminum
transverse links, liquid filled L-arm rear bushings, crossmember stiffener bar, coil
springs, stabilizer bar and negative-scrub geometry
Rear MacPherson-type inverted struts with coil springs, crossmember stiffener plates, trailing
arms, twin aluminum parallel links and stabilizer bar and negative-scrub geometry
2006 Subaru Impreza WRX STI Specifications / 2
Brakes Power assisted 4-wheel disc with 4-channel, 4-sensor Super-Sport anti-lock brake
system (ABS) with g-sensor; Electronic Brake-force Distribution (EBD)
Front disc size 12.7 x 1.2-in., ventilated with four-piston fixed position calipers
Rear disc size 12.3 x 0.8 in., ventilated with twin-piston fixed position calipers
Steering Quick-ratio rack-and-pinion with engine-speed controlled variable power assist, loadsensing
valve, variable-capacity power steering pump and power steering fluid cooler
Ratio 15.2:1
Turns, lock-to-lock 2.7
Turning circle 35.4 ft.
Wheels 17 x 8JJ BBS brand aluminum alloy
Tires 225/45ZR17 Bridgestone Potenza RE070 summer/directional
Exterior Dimensions
Wheelbase 100.0 in.
Length 175.8 in.
Height 56.3 in.
Width 68.5 in
Track (front/rear) 58.7 in. / 58.9 in.
Ground clearance 5.7 in.
Curb weight 3,351 lb.
Interior Dimensions
Headroom (f/r) 38.6 in.
Legroom (f/r) 42.9 in.
Hip room (f/r) 53.3 / 51.9
Shoulder room (f/r) 52.7 in. / 52.9 in.
Trunk volume 11.0 cu. ft.
EPA interior
volume
87.6 cu. ft.
EPA class Subcompact
Capacities
Fuel 15.9 gal.
Engine oil capacity 5.3 qt. w/ filter
Coolant capacity 8.1 qt.
Fuel Efficiency
EPA city mpg 18
EPA highway mpg 24</TD></TR></TBODY></TABLE>
http://www.subdriven.com/news/publish/Subaru_News/article_388.shtml
Bet it looks better in person. Not sure how I feel about that first "wing" just above the rear windscreen.
Looks like there is still no rear window wiper :(, that sucks. I think the WRX got the biggest change with 4-pot brakes,17's, leather seats, and of course the 2.5. Mikey when you get a chance can you post 06 WRX specs? Thanks.
Edit: nevermind :D
Bleh. I hate when they come out with new years of cars, they don't really change much. They only change a few things that make you think that it's changed. (flash)
New Threads
