OBD Fusion Update
Sharing, apparent update to OBD Fusion added enhanced diagnostics for Mazda 2025 and 2026. Not sure what this update entails. Maybe someone else already knows what is on the update for Mazda owners?
Ahh, gotcha. So for a non-Desktop license user really a nothing burger. Thanks for sharing. I was hopeful it might have expanded/enhanced for the mobile app user.
You need the enhanced diagnostics to display things like individual tire pressures, short and long-term fuel trims and hundreds of other PID's
You can view rear diff engagement as well. Forscan being discussed here but you can also view with OBD Fusion/Link. Be sure to double the value shown to see correct percentage of engagement.
The enhanced diagnostics aren't needed to see the second coolant temp value as two coolant temp values are included in the standard ODBII data points.
Thank you that's good to know! 👍
The only 4WD related sensor I found in the Car Scanner Pro app is the coupling solenoid duty cycle with a % value. It was fluctuating between 1% and 14% for the most part of my 2-hr drive this morning. It never showed a steady value. 🤦
It won't stay steady, the solenoid is very active constantly adjusting torque split.
Thank you! I noticed this morning that it was around 7-9% at highway speed and 16% when 30 mph. On a longer drive yesterday, the log shows fluctuation up to 55%.
Sorry to OP about the detour. 🤦
I was told in the past you had to double the percentage to get accurate distribution but maybe that is no longer the case
The percentage is a measurement of the duty cycle of the solenoid but does not have a correlation to a torque distribution amount that would be easily correlated unless you had access to the maps in the 4wd module. Amperage on the solenoids are generally 0-3 amps, the higher the amperage the higher the amount the electromagnetic clutch set pushes against the main clutches. For example, you are at highway speed with very little engine torque being produced, if the module called for a '50/50' split it takes a lot less clutch engagement to hit that number vs a hard launch where it requires a large amount of clutch application to achieve the same split.
