Nocturnalspeed's Welcome & Build Thread
CitizenPro
behind the scenes
Contributor
2017 Shelby GT350
List of current Modifications (Updated: October 16th, 2014)
ENGINE:
Haltech – Platinum Sprint 500 Engine Management System w/ PCM Extension Harness
K1 Technologies - Long Rods
Wiseco - 8.5 to 1 Forged Pistons
O-Shi Motorsports - Stage 2 Ported Head
SuperTech – Stainless Steel Intake/Exhaust Valves (1mm Oversized)
SuperTech – Valve Springs & Titanium Retainers (Dual Spring for High Boost)
SuperTech - Bronze Valve Guides
Integral – Stage 2.5 Intake/Exhaust Turbo Cams
Focus - Adjustable Cam Gears
Jay Racing – Hi-Flow Fuel Rail
Aeromotive - Fuel Pressure Regulator
Walbro – Hi-Flow 255lph Fuel Pump
Deatchwerks – Hi-Flow 750cc Fuel Injectors
NGK - V-Power ZFR7F-11 Spark Plugs
Injen – Short Ram Air Intake
ATP – Wastegate Actuator
AEM – DryFlow Synthetic Air Filter
TurboLife – Front Mount Intercooler
HKS – SSQ Blow off Valve v3
505 – Aluminum Intake Manifold
Outlaw Engineering – Thermoblok Spacer Kit
Vibrant – Aluminum Vacuum Manifold
Vibrant – Silicone Vacuum Hoses
Perrin - Oil Catch Can
Medieval – Aluminum Alternator Pulley
Medieval - Aluminum Water Pump Pulley
Medieval – Aluminum Power Steering Pulley v2
SFI Pro - Racing Billet Harmonic Damper
Mazda Genuine - Millenia PCV Valve
Perrin - Coolant Overflow Tank
CR3 - Aluminum Air Diversion Panel
CR3 - Aluminum Radiator Brackets
AWR – 3501 High Performance All-Aluminum Radiator
AWR - Aluminum Fan Shroud
SPAL – 12” Slim-line Radiator Fans
Samco – Upper Radiator Hose
Speedcircuit - Thermostat Outlet Kit
SteedSpeed – Turbo Exhaust Manifold
ARP – Exhaust Manifold Studs
P.E.P. – 3” Downpipe w/ Flex
AWR – Complete Engine Motor Mount Kit
Optima – Yellow Top Battery
QTP – 3” Electronic Exhaust Cutout
PowerFab Auto - 3" 304 Stainless Steel Custom Exhaust System
w/ Vibrant 3” Standard Bottle Style Resonator (12” Long)
w/ Vibrant 3” Stainless Steel Race Muffler (5” Long)
Corksport – Urethane Exhaust Hangers
DRIVETRAIN:
TWM – Short Shifter w/ Polyurethane Bushings
Goodridge – Stainless Steel Braided Clutch Line
ACT – Heavy Duty Street/Strip Clutch
Fidanza – 7 lb. Aluminum Lightweight Flywheel
Quaife - ATB Helical Limited Slip Differential (LSD)
ARP – Limited Slip Differential Bolt Kit
Royal Purple - Max-Gear 75w90 Transmission Oil
SUSPENSION/BRAKES:
Ksport - GT Pro Coilover System
AAC - Wilwood Super-Lite 6 Piston Front Big Brake Kit
Goodridge - Stainless Steel Braided Brake Lines
GT Spec – Front Strut Tower Brace
GT Spec – Front Lower Tie Brace
GT Spec – Front 4 Point Ladder Brace
GT Spec – Rear Trailing Arm Braces
GT Spec – Rear Link Reinforcement Panel
GT Spec – Rear Reinforcement V Braces
GT Spec - Complete Trunk Cage
AWR – 20mm Urethane Rear Sway Bar Bushings
Pedders – Front Control Arm Bushings
Pedders – Rear Trailing Arm Bushings
EXTERIOR/WHEELS:
Volk - TE37 Forged 1-Piece Wheels 18" x 7.5"
BFGoodrich - g-Force Sport Comp 2 Tires 215/40/18
Ichiba – 10mm Front Wheel Spacers w/ Extended Studs
Ichiba - 10mm Rear Wheel Spacers w/ Extended studs
DG Motorsports – Carbon Fiber Front Grille
Xcelerated Concepts – Carbon Fiber Reverse Cowl Hood
Xcelerated Concepts – Carbon Fiber Trunk Lid
iSport - Carbon Fiber Roof Cap
Aerocatch - Lockable Hood Latches
AAC - Bumper Brackets
MattV - Bi-Xenon Retrofit Headlights
DDM Tuning - HID 4500K Headlight ballasts
DDM Tuning – HID 4500K Foglights
INTERIOR/ELECTRONICS:
DaveB – Aluminum Brushed Gauge Rings
ForceFed – Dual Cluster Gauge Pod
ForceFed – Carbon Fiber Trimmed Radio Bezel
AEM – Digital Boost Gauge
AEM – Digital Wideband UEGO Gauge
HKS – Electronic Valve Controller Type-S
HKS – Type-0 Slim Turbo Timer
Mazdaspeed – 03.5 Shift Knob
Nocturnalspeed's first purchases...
Eibach Pro Kit Lowering Springs
Ichiba 10mm Wheel Spacers w/ extended studs
TWM Short Shifter w/ Bushings
Goodridge SS Clutch Line
AWR Motor Mounts 88 & 95 Duro
Peddars Front Control Arm & Rear Trailing Link Bushings
GTspec Bars minus the Trunk Cage
AEM Digital Wideband UEGO Gauge
AEM Digital Boost Gauge
HKS Type 0 Slim Turbo Timer
HKS EVC-S Controller (EBC)
Now Installation of the short shifter and bushings, rear sway bar bushings, Gtspec Bars! Ill be
installing more items next weekend.
- David
looks super clean! what kind of mods are you looking into? spicys my favorite color :)
Thx! :D I listed most of them on my second post, but the once I'm currently waiting for are: SteedSpeed - Turbo Manifold & ForceFed - Dual Cluster Gauge Pod
I'm currently looking for the GT Spec - Complete Trunk Cage (Blue), '03.5 Mazdaspeed - Aluminum Pedals, DaveB - Gauge Rings, 3" Downpipe & 3" Electronic Cut-out.
I think my next mods I'll be installing this weekend are: Ichiba V1 10mm Wheel Spacers and Eibach Springs. So keep checking back for future updates. (drive)
- David
Wow I'm jealous lol all those new parts. Looks awesome! I hope to see it sometime being local. By far one of the best colors too. Welcome also
Thx man! I couldn't believe how gorgous she looked when I went to pick her up. It was like a dream come true.
Yeah I hope to meet some other mazda owners in the Houston area.
now don't be a stranger.
were gonna have to have a msp meet soon.
My brother mentioned to me about the Project M meet, but the GT Spec bars took longer then expected. (low_psi) was there that day. Sucks we couldn't make it.
quick start to mods! car looks great, love the color
Thx! :)
lookin good got a nice start goin ;) now start makin that power lol
You must crawl before you walk ;)
Getting her built from the ground up first. After I purchase most of the supporting mods; such as, fmic, manifolds, cai, ems, dp, cutout/exhaust (not sure which one yet) etc. I'll purchase a built block and head with all the guts.
Don't worry, power will come in the near future.
i got a CF hood and trunk for sale if you want them.(silly)
oh i have a 3'' cut out sitting in my garage if you want it.
niiiccceeee, i like the car so far, wish i had a bone stock car to start over with knowing what i know now lol
car looks clean, keep up the good work (thumb)
hate to sound like a vulture, but would you be willing to sell your passenger side motor mount after you install the AWR parts?
I almost want to advise against modding it at all. Too mint! But its just a Protege, hack it up!
^ Was thinking the same thing at one point....until he gave me all access to his money and said, "build me."
lol that sounds like fun
Yeah and he almost had me broke!
Had to change my paypal password before he overdrafts my account like crazy. He thought I said, "I'm going to buy the Rotora BBK" but what I really said was, "I'm thinking about buying the Rotora BBK" (hand)
Which I still am at the end of the year, but want a few more things that I can't purchase new; such as, GT Spec Trunk Cage, DaveB Rings, Turbolife FMIC, ect ect.
Similar Threads and Articles
