- 2017 Shelby GT350
List of current Modifications (Updated: October 16th, 2014)
ENGINE:
Haltech – Platinum Sprint 500 Engine Management System w/ PCM Extension Harness
K1 Technologies - Long Rods
Wiseco - 8.5 to 1 Forged Pistons
O-Shi Motorsports - Stage 2 Ported Head
SuperTech – Stainless Steel Intake/Exhaust Valves (1mm Oversized)
SuperTech – Valve Springs & Titanium Retainers (Dual Spring for High Boost)
SuperTech - Bronze Valve Guides
Integral – Stage 2.5 Intake/Exhaust Turbo Cams
Focus - Adjustable Cam Gears
Jay Racing – Hi-Flow Fuel Rail
Aeromotive - Fuel Pressure Regulator
Walbro – Hi-Flow 255lph Fuel Pump
Deatchwerks – Hi-Flow 750cc Fuel Injectors
NGK - V-Power ZFR7F-11 Spark Plugs
Injen – Short Ram Air Intake
ATP – Wastegate Actuator
AEM – DryFlow Synthetic Air Filter
TurboLife – Front Mount Intercooler
HKS – SSQ Blow off Valve v3
505 – Aluminum Intake Manifold
Outlaw Engineering – Thermoblok Spacer Kit
Vibrant – Aluminum Vacuum Manifold
Vibrant – Silicone Vacuum Hoses
Perrin - Oil Catch Can
Medieval – Aluminum Alternator Pulley
Medieval - Aluminum Water Pump Pulley
Medieval – Aluminum Power Steering Pulley v2
SFI Pro - Racing Billet Harmonic Damper
Mazda Genuine - Millenia PCV Valve
Perrin - Coolant Overflow Tank
CR3 - Aluminum Air Diversion Panel
CR3 - Aluminum Radiator Brackets
AWR – 3501 High Performance All-Aluminum Radiator
AWR - Aluminum Fan Shroud
SPAL – 12” Slim-line Radiator Fans
Samco – Upper Radiator Hose
Speedcircuit - Thermostat Outlet Kit
SteedSpeed – Turbo Exhaust Manifold
ARP – Exhaust Manifold Studs
P.E.P. – 3” Downpipe w/ Flex
AWR – Complete Engine Motor Mount Kit
Optima – Yellow Top Battery
QTP – 3” Electronic Exhaust Cutout
PowerFab Auto - 3" 304 Stainless Steel Custom Exhaust System
w/ Vibrant 3” Standard Bottle Style Resonator (12” Long)
w/ Vibrant 3” Stainless Steel Race Muffler (5” Long)
Corksport – Urethane Exhaust Hangers
DRIVETRAIN:
TWM – Short Shifter w/ Polyurethane Bushings
Goodridge – Stainless Steel Braided Clutch Line
ACT – Heavy Duty Street/Strip Clutch
Fidanza – 7 lb. Aluminum Lightweight Flywheel
Quaife - ATB Helical Limited Slip Differential (LSD)
ARP – Limited Slip Differential Bolt Kit
Royal Purple - Max-Gear 75w90 Transmission Oil
SUSPENSION/BRAKES:
Ksport - GT Pro Coilover System
AAC - Wilwood Super-Lite 6 Piston Front Big Brake Kit
Goodridge - Stainless Steel Braided Brake Lines
GT Spec – Front Strut Tower Brace
GT Spec – Front Lower Tie Brace
GT Spec – Front 4 Point Ladder Brace
GT Spec – Rear Trailing Arm Braces
GT Spec – Rear Link Reinforcement Panel
GT Spec – Rear Reinforcement V Braces
GT Spec - Complete Trunk Cage
AWR – 20mm Urethane Rear Sway Bar Bushings
Pedders – Front Control Arm Bushings
Pedders – Rear Trailing Arm Bushings
EXTERIOR/WHEELS:
Volk - TE37 Forged 1-Piece Wheels 18" x 7.5"
BFGoodrich - g-Force Sport Comp 2 Tires 215/40/18
Ichiba – 10mm Front Wheel Spacers w/ Extended Studs
Ichiba - 10mm Rear Wheel Spacers w/ Extended studs
DG Motorsports – Carbon Fiber Front Grille
Xcelerated Concepts – Carbon Fiber Reverse Cowl Hood
Xcelerated Concepts – Carbon Fiber Trunk Lid
iSport - Carbon Fiber Roof Cap
Aerocatch - Lockable Hood Latches
AAC - Bumper Brackets
MattV - Bi-Xenon Retrofit Headlights
DDM Tuning - HID 4500K Headlight ballasts
DDM Tuning – HID 4500K Foglights
INTERIOR/ELECTRONICS:
DaveB – Aluminum Brushed Gauge Rings
ForceFed – Dual Cluster Gauge Pod
ForceFed – Carbon Fiber Trimmed Radio Bezel
AEM – Digital Boost Gauge
AEM – Digital Wideband UEGO Gauge
HKS – Electronic Valve Controller Type-S
HKS – Type-0 Slim Turbo Timer
Mazdaspeed – 03.5 Shift Knob
