No A/C, compressor rebuild?
BenjiHoggi
OEM+
Oregon, USA
22v Protege5
My air conditioning stopped working last summer and now that it's getting warmer, I'm trying to fix it on the cheap.
Here's where I'm at
  • The compressor seems to not be kicking on even with the AC light on.
  • I have the Harnessed Performance AC light flicker harness so this is not *that* issue
  • I have not checked the refrigerant level but I suspect the problem is not a leak. The AC worked great, I parked the car for a weekend, came back to no AC.
  • I used to hear a click from the compressor when AC was engaged (assume this was the clutch kicking in). I no longer hear this click.
I'm inclined to think this is a clutch issue, so I'd really like to investigate a solution that does not involve replacing the compressor or refrigerant. To begin with, I'd like to check if the clutch and associated components are working correctly. Has anyone done this and how?
From my research, I've found the following threads which seem related.
Replacing A/C Compressor, please double check my process - maybe a little past what I'm looking to do right now, but helpful
I've also found that eBay has non-OEM clutch kits for around $100. I would tend to not trust these but curious if anyone has thoughts?
Anybody have experience with this?
I'm an idiot. As always when posting these kinds of things, I keep researching after posting to try and understand the problem more. I went out to try and test the resistance on the clutch coil and the clutch is just gone.
Literally exactly what happened here.
Sadly the parts are just gone, so I am going to try and source new ones for cheap and reinstall them.
Upvote 0
Bought this AC compressor clutch kit.
It came with the clutch, pully, and magnetic thing.
I sanded and wiped down the old pulley and pressure plate on the compressor because I didn't want to risk the cheap China bearing in the Amazon kit and the original bearing and pulley were still good. Because of this, the clutch chattered for a few days when the AC was off but now it's mostly quiet.
And the AC works great, which is surprising for 212k miles and non AC service in the last 70k miles and 6 years of ownership.
Upvote 0
