Nickel or Zinc plating rims
2014 CX-5 Touring
So I just picked up a set Mistubishi Eclipse 18" rims to put on Old Blue ('14 CX-5 Touring) and spruce it up a bit from the stock 17's. Their the same bolt pattern, hub size, and a close enough offset (46mm) all for $120. I've been debating painting the rims, plasti-dip, powdercoat, or maybe zinc or nickel plating. Anybody have any experience with the plating route? A cousin owns a company that does the plating and I wanted opinions before I hit him up it.
Pic of wheels
  • 2021-01-30 19_23_41-Marketplace - Mitsubishi factory OEM rims (set of 4) _ Facebook.webp
Plating should be the most durable and likely will help with resell value as long as you get some common colors. Since your cousin can hook you up, I think it's a no brainier.
