OK....God knows this has been brought up enough, so I'll keep it short & sweet.
I just got off the phone w/ NGK, and they recommend that if your looking to step a heat range colder, then go w/ the PZFR7G-G (stock plugs are PZFR6F-11). This plug has the exact same specifications as the stock plugs, one step colder & also have the copper core to help dissipate heat build-up (that's what the last "G" signifies). I was also told that going two steps colder may make the car virtually undriveable during normal conditions due to fouling out. (I initially asked about the BKR8EIX...an iridium plug).
Also....Our stock plugs are double platinum, NOT iridium. The iridium plug I mentioned above has the almost the same spec's, but projects 0.2 mm less into the cylinder (*as well as the BKR7EIX*). Well...that's some food for thought at least. I just thought I'd let you all know.
