NGK Iridium Plugs PreGapped??
ComeBack
Mazda MazdaSpeed3
Hey i just got my NGK Iridiums from PG and i can't find anywhere if the are pre gapped or not. Also is there anything special i need to know before installing these?
Thanks (breakn)
(ps: ive already searched)
Well even if they do you should check them with a wire spark plug gapper tool:
Manual says .028-.031" is in spec.
They come pre-gapped. You can check to make sure they are o.k. I used a 28 thousandths wire and a 32 thousandths wire for go-no go checking. All were fine.
They are not meant to be re-gapped and can be very easily ruined by trying. If the gap ain't right (not likely), get some that are.
I got mine (NGK Iridium IX) from the local O'Rileys Auto Parts Store! Cheaper too than any of the internet vendors I had checked.
My NGK's were not gapped for the turbo engine, which is .028 to .031 and had to be regapped with the appropriate tool. As Sport6 suggested, get a tool and check them.
You are right. I did not recall having to regap them, although I did recall using the .028 and .032 wires for no and no go gauges.
The things come pre-gapped at .044 which is way too big for our application
http://www.ngk.com/more_info.asp?AAIA=&pid=20936
The tip is very delicate, so be careful, but yes, bring them down to the proper spec. Thanks for catching my bad, and my bad memory!
