Used a racing stop watch. I never had one of those things you plug into your cigarette lighter, always wanted to try one and compare there accuracy. I was thinking of installing what I use on the race vehicle and setting up beacons for more accurate testing, as I'm timing and shifting all by myself so it's not the most accurate, but you do what you do. The distance is the true measurement since timing can very when you have to do it all at once, but I used to do that before I bought a timing system for the race vehicle, so I got fairly proficient at it. Makes me wonder if you went to an NGK racing plug if you could even find better results. They can be nearly $100 dollars a plug. I was pretty blown away with the results though, never seen that kind of improvement from a plug change before in any vehicle. I was also surprised to see how lean the stock plugs looked when I pulled them out. We never even run are race vechiles that lean. The only mod I have on the car is a K&N filter. I didn't notice a big change with it, more in the gas mileage and and about 150-200 rpm drop at cruising speeds. I'm wondering if one of those tornado things would actually make more power. I've sold some recently but haven't had any reports back. In our race vehicles we used something like the tornado to break up the air and depending which one you used you could find big gains. I was curious though? I haven't had a chance to get my MSP on the race track and wonderng what is top speed on this car and is it drag limited or electronically limited?
