nope. you're gonna rub the crap out of those tires, that's all. if you enter a turn hard, you'll rub. if you have people in the back and turn easy, you'll rub. running 215 tires on a 7.5" rim needs a +48 offset to fit. that's 8mm you're under, so you'll rub. guaranteed. 8mm off on the offset would basically mean your wheels will either sit right under your fender lip or it'll stick out a tad.
edit: i take it all back. i thought i read your wheels are 7.5" wide... but since they are 7" wide, you will still rub, but not so bad. you'd want to run 205 tires instead of the 215 though cause 205 with a 42 offset will barely make it according to the fitment recipe. with 215 tires, you'd want +45 offset. so yeah... good luck.
