At long last... some pictures...
Here is a picture of the light against the garage door (<3 feet) with DRL off as the car was off:
After messing around with the settings and looking suspicious at night sneaking around with a camera and moving the car to various spots around a parking lot, here are some pictures. They're not great (gotta learn to take better beam pattern / cutoff pictures). Unfortunately, I don't have a light meter available. I have also tried researching what camera settings forum member 'sac02' used for their review of an LED headlight bulb by a forum vendor (
http://www.candlepowerforums.com/vb...wall-amp-lux-comparison-LED-H11-LL-H11-100-H9 and
http://www.candlepowerforums.com/vb...ic-driving-evaluation-LED-H11-LL-H11-100-H9); but was not conclusive. Keep in mind that their test was conducted on a Mazda 5 (not CX-5), which may or may not be designed similarly since the beam pattern and cutoff looked different. That being said, I am still unable to capture how the eye really perceives the beam. Settings used was ISO 800, f/4.0 , 1/5s, WB set to 5000K.
The following pictures are on-road shots. 1 big disclaimer is that my LED DRL is still on full brightness due to not having the cabling fixed to dim/turn off the LED DRL when headlights are on (cabling was affixed to the HID setup). This means that glare will be greater (as light is spread upwards) and foreground illumination will be greater (due to DRL being on full brightness). Fix is in the works but here are the pictures to start things off:
Side of road, slight incline (down road road-side sign illumination is alright; the speed limit sign is probably lit by the LED DRLs):
Parking lot (~9 spaces width in distance):
Parking lot against a truck (couldn't find a suitable wall, you can see the DRL on full brightness):
Slight incline, Acura MDX with "Jewel Eye" LED headlights passing by (couldn't take the shot earlier - low light focus is slow; but the MDX was MUCH brighter; might be able to match the width of the beam pattern if I had the same bulbs for LED fogs as well hehe):
Honestly for the money (spent about $50 for a pair), these LEDs are alright as halogen replacements (kinda like running a brighter version of 'xenon look' blue bulbs - but this observation is coming from running Morimoto 4300K 35w HIDs with ~3100LM output for about 6 months; so I lost over 1000LM) but besides the unique look with the blue/purple tinge (and a blue/white-ish beam) like the MDX or the new Corolla, the best way is to either upgrade to factory HID or retrofit with appropriate lenses and corresponding lighting source that is designed properly. I will continue to run the LEDs for a while to experience various conditions with them to get a better idea of its strengths and weaknesses but for now, I'm leaning towards going back to the Morimoto HIDs and maybe stuffing these into the fog light housing. On the 'bright side' of having less lumens, I can see better further down the road since the foreground light isn't overwhelming.
Here's a shot of the projector with the blue/purple tinge (which I believe the LED is emitting 6000K but the lens design is creating this effect; I noticed similar effect with 4300K HIDs as well):
Last photo is for beam throw, the yellow dead end sign reflecting back (the speck in the middle) is about 600 feet away (I'm at the top of the hill, there is a metal halide street lamp directly above me):
