Thanks for everyones help....The problem was NOT with the SSAFR, I had some other issues with the car....MAF wire was pulled out, vacuum leak at vacuum manifold, spark plug gaps were way off (.050) so now she is running like a champ....I just have an idle issue....super low idle after warm up (200-500) and will eventually stall and die....I belive it has something to do with the clutch switch because the idle does change depending on if clutch is in or out....Once I find and repair the issue I will update....If anyone has an idea of what it could be i'm up for some insight
