need help
WRCprotege
03 Protege5 91 miata
hey guys i just did another motor swap, however ther a plug that come out of the tranny, that has no where to go.. that i can find,, i need someone that can look under ther car and tell where this thing goes.. thanks
jason
Didn't know the manual tranny had any plugs. Sorry, I would go look at mine if I hadn't traded it in last weekend.
I just remembered, it's for your backup light. There should be another plug under there somewhere to connect it to. You probably moved it when you were swapping out the engine. Check the wiring harness for a plug that is not connected to anything.
Did that. Can't find one that's not connected. And the back up lights work without that pluged in.
neutral switch i think.. the car idles high when clutch is out, i push the clutch in and its good.. can anyone look to see wher it goes.. harness, firewall etc.... thanks
