need help with msm fuel problem
Status
Not open for further replies.
msmmx5
i have a msm with the fm complete intake, fm complete exhaust, fm 02 siginal modifier, turbonetics boost control. The boost is set at 8 psi( the lowest the control valve will go) and when under full throttle i am getting detination around 5500 rpm. My stock ecu wont be aggressive enough to get more fuel. I recently learned that the hydra nemiss wont be smog approved. What should i do?????
Look into another EMS?
When you say "I am getting detonation" are you hearing sounds of knock?
If so, I heard knock when I first got the car, it went away when I put in the Xede EMS. I remember thinking I bought a broken car, but it "went away."l
If you want more fuel, look into bigger injectors. I have my old ones for sale, if you are interested.
My setup was 440cc RC Injectors w/ the Xede EMS.
yes im very interested. but i still will need some kind of an ecu to be able to change the injectors wouldnt i? where do i find out more about the "xede ems"
bellengineering.net
Shiv took down all the MSM Xede information from his website, I believe.
thanks, how much for the injectors? do you know what the ccs are for the factory injectors. i checked out the xede. looks promising. did you install it or did you have someone else do it for you?
The stock injectors are 260 or something like that. I installed the Xede myself, I'll be more than happy to walk you through the process. It's a simple install, the injectors however, are far from simple.
The injectors I'm selling are $250. This includes everything you need, ie: clips.
Status
