Need help quick!!!
Hit it with your purse?
Try some lube. Even a bit of wd-40 can help.
i dunno about that, wouldn't you rather use something that will evaporate quickly so it doesn't get all in the engine, or possible come detatched later?
but the purse comment was funny(drinks)
Well hopefully he's using hose clamps so that should stop it from slipping, and you would just use a bit of wd-40 on your finger to lube it up.
That one is straight from the construction site. (drinks)
Got it! Thanks, gents. Took a bit more elbow grease than I thought. I used the stock "pinch" clamp at the recirc/tip connection. Would you recommend two hose clamps at this location.
