Need help/intake leak
02_ES
2002 mazda familia sport20
Hey guys I recently bought a 5 speed protege that needed a little work. I got it driveable and the same day the CEL came on for EGR insufficient flow. Took the intake manifold/EGR off to clean it out and also found that the EGR valve was sticking. I cleared all passages and unstuck the valve as best as I could.
When I started it after I reinstalled everything the car would not idle. There was also a loud hissing noise from the engine compartment. It was running very rough while I held the rpm's around 1000 rpm's, would rev pretty smooth with moderate throttle, and would die as soon as I let off the pedal. I took everything apart to recheck my work and did not notice anything.
I replaced the IM gasket, TB and EGR valve gasket. It's still the same. The hissing noise is coming from somewhere below the throttle body area it seems. I tried spraying carb cleaner around the area but could not find the leak. (scratch)
Any help or suggestions would be greatly appreciated. Thanks in advance
It ended up being the EGR valve stuck open. Got it operating smoothly now, runs better than ever. This car is a killer daily driver.
Someone have any input on shifter bushings?
