Spiced MSP
- 2016 Peterbilt 579
Ok, I am replacing my water pump and so far I have removed 5 bolts from the pump. As far as I know, there are only 5 bolts that hold the pump onto the block. But for some reason, I can't get the pump to come off at all. Is it just suction from the pump that is holding it on or am I missing something? Also, Im going to do the timing belt as well. When you take the crank pulley off, if that notch on the crank is pointing directly up, does that symbolize TDC?
