it only comes with the green spring...i want to say it's around $15 for a different spring.
fwiw, i'm replacing my new forge...it does not hold boost well at all...the turbo will spool-up just fine and at around 4500 rpm's, the boost starts to drop. the WGA is fed off of the turbo housing, so i know i have a reliable source.
this was the response i was given from forge about my problem:
With just a constant pressure source acting on the actuator, it will respond directly to changes in pressure immediately as generated by the turbo based on various ambient conditions and load levels.
You may wish to manually adjust the pre-load of the actuator, but also, incorporating some sort of manual boost control (mechanical or electronic) will undoubtedly allow you to dial in your target pressure much more affectively
