- Denver, CO
See this is what I'm thinking.The tire rack description says theyre symmetrical. I think you have two different tires......
Sorry yrwei, too dark for a photo, but I did look when I bought them and they are 51 psi max.
Usually 225/65R17 tire has 100~102 load index. There's no way a tire with this size is having 94 load index. And RT43 doesn't have V-rated tire for this size, but only H and T rated. Can you verify the tire size on the tires with 94V?94V was my Camry tire which is on order as well. So they mixed up.
Does this mean one tires are smaller in size than other? If so will it have an impact on my cars life? I think it is 215 but I am out of Texas now.And I bet they*re *215/55R17 94V*!
215/55R17 94V definitely is smaller than 225/65R17 102H hence the load index is lower. The maximum load is 1477 lbs. on LI 94 and 1874 lbs. on LI 102.Does this mean one tires are smaller in size than other? If so will it have an impact on my cars life? I think it is 215 but I am out of Texas now.
It*s not good for your differential long term to always have that rotation difference. I imagine it could also throw off systems like stability control. Definitely get it addressed asap.
Kaps has a FWD CX-5 and there're less issues with different sized tires. At least he doesn't need to worry about burnt-out rear differential clutch pack but some brake pad wearing! It can't be worse than putting on our 2~3" smaller on diameter mini spare.Its not good for your differential long term to always have that rotation difference. I imagine it could also throw off systems like stability control. Definitely get it addressed asap.
But yeah, Kaps needs to get this thing resolved ASAP.
Like I said in the previous post, no worries. Just pretend you put our mini spare on.I will get it fixed and total would be 12 miles or so driven with the mismatched tires all under 50 mph - should this hurt at all? Disco T is nearby. Really sad they did this - angry that i did not check.
Yeah honestly if those tires are indeed different sizes and it seems they are, then that is a pretty big amateur hour screw up on Discount Tire's part.Like I said in the previous post, no worries. Just pretend you put our mini spare on.
But I'd discuss this issue with store manager if you can verify they really mixed up different tires. May be you should ask for some partial refund or store credit toward future use as this could damage the vehicle if you didn't notice the "94V" discrepancy by yourself!
