The original 2.3 engine went out in my car. I swapped a 2.3 out of a Fusion. I kept my engine harness and PCM, intake camshaft, intake manifold, TB, fuel rail & injectors.. Used this guide:
http://www.happywrenching.com/mazda/6/mazda-6-and-ford-fusion-23l-engine-swap.html
Anyway, I don't know what this sensor and bracket is/where it goes. It looks like it a ground of some sort.
It is the only connector between the grey (at least on my car) O2 sensor and the crankshaft position sensor. It is a little black sensor with a crazy U-shaped bracket that has a notch in it. I mounted it here (timing cover):
The car does run and drive ok at best. I'm getting a P2507-low PCM voltage. I also had P0012-camshaft position timing overretarded, but that is now gone.. I tested battery with multimeter and it reads 12.5 when the car is off. I'm getting 13-14 while it is running and with AC on full blast and/or reving up to 2500rpm.
Also, my transmission seems to shift funny (it is a 5 speed manual), but not consistently. It feels like it won't go into gear at times.. I never had this problem before. I used new transmission fluid (3 quarts).
Can anyone help me out please?
Thank you!
Thank you!
