phunky.buddha
Booga Booga?
- DFW TX
- No mo MZ5 want MX5
So while I was in the shop today resetting the ride height of my BC Coilovers which I still owe this forum the full writeup on, I figured I'd throw the 5 on the dyno for fun.
Here are the charts. The first run had the best power measurement (coldest engine run), but I forgot to shut the AC off- you can see where the compressor kicked on and off during the run... and I thought they were normally supposed to off at full throttle.
You can see the power going down as the runs go on- the engine was starting to get heat soaked a bit, but repeated a few runs right at 140whp.
I sprayed the intake manifold with water to cool it down some and waited about 15 minutes before running again:
Not bad. 143whp/141wtq is really healthy for a 70k mile engine, especially since the published factory power figures are only supposed to be 153hp/148lbft at the crank. We (at the shop) usually figure in 17% for driveline loss on a manual 2wd car, so this would put my crank figures at 172hp/170lbft. Even at a more aggressive 15% that puts me at 168/166.
Drivetrain is totally stock @ 70k miles (2009 model) except for a drop in K&N filter (I won't accept that it adds any power) and Pennzoil Platinum full synthetic oil. Wheel are 2010 MX-5 (17x7 +50) and tires are 215/50-15. I just thought I'd post it up as a data point for any of you that might find it useful.
