peepsalot said:I tried to get DSMconvert to make me a MAF setup like this from his hardpipes, but I guess at the time he was busy developing the AFC's. I got tired of nagging him about it and gave up.
I wonder what that would involve. I mean, the AFC already has a MAP builtin. Would it just be a software change?CasopoliS said:In the future he might do some work with this. Possibly making a MAP setup for the MSP. This would be compatible with the AFC, and get rid of the MAF setup.
MetalSpeed said:CASPOLIS,
So your doing the dual setup right.(BPV,BOV)
CustomMSP said:As soon as you give gas after shifting the BOV closes shut because of the boost in the line going to it. Therefore you have no extra air escaping.
CasopoliS said:So are you saying the BPV doesn't help with any sort of performance?
igdrasil said:what you mean? does the MSP BPV leaks under boost?
CasopoliS said:I have the Boost Sciences Reflex BPV. You still think it is not good to have this within my setup? I know it is not needed for funtionality, but ideally you have to recirc some air for low boost applications. I would love to recirc it all acually, but I hated the way it drove like that. It always drives better with dual valves and even better with the MAF movement, but I have no idea why.
igdrasil said:Its a MAF issue and its placement. I have even seen that moving the maf will also help with the turkey issue.
I was running some experiments over the weekend with a few IC setups and blew off the cold pipe at the IC while boosting like 7psi. The backfired so hard and loud I thought my engine blew! I was able to drive the car fine with the pipe blown off home because of where the maf is.
I had my intake setup as SRI until recently. I switched it to CAI and that is how I am running now. I had idle problems before and they seem to be about the same now. No noticable difference in idling between either setup.All Boost said:Sorry to hear about your adventure. I had a quick question though. Since the fan comes on and hit the airbox/cone with hot air, making it stumble/idle poor.
Are people with CAI having better idle? i was thinking of making an extension from the stock MAS position to inside the wheelwell to try and fix that problem.
genius said:Ok guys, I am sold. I got my hands on some 2.75 to 2 reducers. The only thing left is, that the easiest place to put the maf is about 6 inches away from the TB just after a 90 bend. Is that too close? I could move further away but that would mean extra cutting and painting
