Okay new updates ....
THE MAZDASPEED:
So far the emanage and the mazda have not been the best of friends... we tried to tune around the fact that we couldn't use the airflow meter or crank angle sensor involved features. ... well the car seems to be able to retune itself as fast as we can. The first problem we ran into was a nasty lean condition on tip in when we were tuning the A/F by throttle position and RPM. When we added in the GReddy pressure sensor, tuning became easier, and eliminated the lean out problem. However the car still wanted to override our settings, i should have checked the fuel trims, but as you can see from the post above this we had some issues not related to the car before we finished. Our next addition will be the flying miata o2 signal modifier. this will basically keep the stock ECU from being able to read from the O2 sensor when under boost, keeping the engine from being able to trim fuel based on this.
Now on to
THE IS300:
where to start.... i checked the emanage against the scan tool today, ignition timing is 1-2 deg higher on the emanage, which can be offset in the software. The Intake temp and water temp were w/in a couple of deg of each other w/ the emanage reading a little higher (1-2 deg max). I have been playing around tuning a little bit, and still have not gotten the Air/fuel to read right on the emanage. GReddy was no help on this, i will contact INNOVATE tomorrow to see if they have any suggestions. The best news is have is that the Rev limit change works! ... honestly i didn't expect it to. This feature will only work on cars that use fuel to activate the rev limit.
this is the "map" to set this feature.....
obviously the map is just roughed in, but it was safe air fuel wise, and allows the higher rev limit. ... Now i just need some valve train and cam upgrades to make use of this feature! :lol:
