^^^ My mods as of right now is Injen CAI, COBB TIP, SU RMM, Denso ITV22's, Forge MBC (@17psi), 3" Turboback (Catless dp/tp, HKS CBE)... HPFP and FMIC/TMIC and tuning tool next...
there is alot of discussion about this subject here, but if your looking plainly for a plug and play REFLASH, not one you can tune yourself then this is for you, if you want to add more and more goodies then I say go COBB..this is plainly for someone who wants the most out of their car with ONLY very minor bolt ons
The is NO low fuel pressure. You're reading the datalog wrong. Trust me, when my stock pump crapped out and dropped to 700 psi over 5000, I noticed it and you would, too, Dashhawk or no.
MBOIZ, why don't you read the threads on this? I'm more modified than you and the HT tune is really pretty good.
If you're measuring what's easier on it, that's harder. Extended idling for "warmup" doesn't heat the cylinders evenly and causes additional wear. A small amount but, real. The best bet is to get through the warmup process as fast as possible,bar racing the engine at high load, obviously.
What? I prefer to let the car idle down and then I start driving it without going into boost. You should never rush the warm up!
