mazdaspeed32007
- Mazdaspeed3
Sorry, I thought it was "premium". That's what I'm switching to at my first change. It's priced better than the Mobile-1 and performs well from what I've read.
I think I'm going to buy the Husky can and run my own tubing. Can anyone tell me what size tubing I will need since I'll be routing it a bit out of the reach of the stock tubing.
Has anyone fabricated a mount for this? Or should I just get a piece of aluminum and bend it in a vice/drill?
i dont know how im going to mount mine but im sure ill think of something once it warms up. as far as tubing goes your going to want vac tested hose. use a fuel hose from napa. i wouldnt suggest buying the homedepot clear hose becuase it WILL collapse after a while. its under constant vac pressure so even if it works for a few months eventually it will give. i cant remember what size it was though. maybe someone else could chime in. your best bet for tapping into the pcv line is cutting the hose thats already there and adding a connector with your hose so you dont have to work way up at the pvc nipple. i made the mistake of taking the whole thing off and it sucked.
