scatt nasty
Banned
- 08 Metropolitan Grey Mazdaspeed 3
Well just downloaded the new maps and took them for a spin.. My mods that effect the AP are CPE CAI, CS TBE, ETS TMIC, BOV, and RPMC Inlet... With the 1.02 maps the ONLY one I could run decently was the Stage 2 ( TBE only, otherwise stock) which wasn't too bad(In cold weather I have the occasional boost cut)... Today I tried the 1.03 maps....
First things first, don't run SF maps with a CAI, I was getting some retarded knock readings. So stage2+SF+TMIC 93 Oct was out the window. Next up, Stage2+MSCAI/TMIC 93 Oct. This map has been doing ok so far, knock reading only hit 1.0-- Boost cut is really hit or miss. However, anytime I downshift and go WOT, its immediate boost cut with it trying to hold 20-21 PSI. If I run through the gears, it will hold 17-18, but sometimes it will cut... If this map still gives me problems I will just go back to the Stage 2 93 Oct which means Ill probably take a hit performance wise, but hell at least Ill be able to even go WOT. I am so sick of boost cut, not being able to floor it sucks.
I am thinking the cut is coming due to my exhaust being catless. This is such a headache, I am going to have to start modding around my AP, which means ditching my CAI for an SRI. The MSCAI is different than the CP-e CAI AP-wise. I'll probably end up ordering the Nano soon and then hopefully I can be done with this.
Please post feedback or similar results, comments and what not...
