I found a place that sells the Stainless Steel adapters that are needed for the oil pressure gauge.
Got to www.mcmaster.com
Search for the following part numbers on the site
part # 4092k11 is a 1/8" Bspt Male to 1/8" NPT F Adapter. This is what you would use if you did not want to use a "T" fitting and just plug the gauge sender directly into the block.
part # 4092K81 is a 1/8" NPT Male to 1/8" Bspt Male Nipple. This is what you would use if you wanted to use a "T" fitting to keep the stock oil pressure sensor.
part # 48805K97 is a SS "T" that has 3 1/8" NPT female sides for use with the male nipple adapter.
For those who have installed an oil pressure gauge are these the correct parts that I listed?
You guys are saying that if the factory oil pressure sensor is not plugged in the dash oil warning light will not come on?
