drkness2003
- 2003 mazdaspeed protege
ok, so i just picked up a 2003 mazdaspeed protege... i drove 4 hours to pick up the car and drove it home with no probs... i got the car home and the next day i was driving to work and it started to hezitate and eventually stall out... i got it into a gas station and tryed starting it and nothing i would crank but not turn over... a check engine light was on but could not see what it was cause i did not have my cell computer... i diconnected my battery and reconnected it and the check engine light was off and car started right up... i brought the car home and checked the cells... i got a
p0660 and a code for running to lean i forget the code... i checked all the vacuume lines and all the plugs and nothing is disconnected... now the car seems to be hezitating very very small while ilding and when i i go threw all gears it seems to died out around 3500-4000 rpms seems like its maybe getting a fuel cut or something... it happends both when i give it alot of gas and when im not getting on it just reg driving... i also had a few times a weird situation i would park my car and have a small amount of coolent on the ground from a hole in my coolent resv. so i decided to check it out, sometimes when i turn my car off i see bubbles coming up in the coolent resv. and feel bubbles in the upper coolent hose... im thinking maybe a thremostat issue or air in the coolent lines? i have also herd checking my vics and vtcs but dont know much about these and location... any ideas and help is very greatfull thanks in advance!!(screwy)(screwy)(screwy)
