MSP engine Needed
Status
Not open for further replies.
.....thats a ridiculous price for a 2.0 get a 2.0 out of a normal protege and swap everything over you shouldnt have to spend more then 700 for a engine
The best I can find for a protege engine with decent mileage is 1,000 around here. I'm thinking that the ease of installation is worth something, plus i don't have to change the tray between the engine and oil pan. So, 1,500 really isn't that bad. Plus I can sell off all of the extra parts off my old engine.
That's my line of thinking....
I have found several under 30K and one under 20K. The main issue is the lack of warrenty. I can't afford to risk any money on something that someone won't warranty against DOA.
i understand that. but them being localish...maybe you can speak to them in person. did they respond yet to your question?
Yeah, he wrote back and said no warranty. I found one with 18K and a 101 day warranty for $1,000. I'm going to call tomorrow and have the junk yard pull it. Now I have to get some motor mounts and gaskets.
Someone in a previous reply indicated that on a MT engine there is a difference with a bold on the starter. Does this mean they have a different starter? What is the difference? I just want to know if I need to get anything else prior to swapping it out.
Thanks in advance
P.S. I've been a member of this forum for over 2 years. For some reason it won't let me post under my old screen name. Butter5784 I really have more post than the 31 my profile says. I may have done business before with some of you. I've bought and sole a lot of things on here.
Thanks in advance
well there's like 2 bolts in one of the trans housings, and 3 bolts in another.. dont really think it has anything to do w/ the motor...
Thanks, I'm calling a junk yard today and ordering an engine with a warranty. I'm also ordering some parts...
I beleive I just need:
1 exhaust manifold gasket,
the two gaskets for the tray between the block and the engine
motor mounts to replace the broken ones.
Is there anything else I should order to do the swap?
not sure what you mean about:
two gaskets for the tray between the block and engine
the oil pan gasket is just RTV.
while you're at it, you should replace the drive belts. and the timing belt..
when are you doing the swap?
I will let you know what I am replacing on the motor I am about to put in the car...
Oil pump...
Water pump...
Gasket Overhaul Kit...
Valve Seals...
Thermostat...
All belts...
Oil Pan Gasket...
Motor Mounts...
ARP Head Studs...
Well, I'm picking up an engine tomorrow at 4pm. I found one with 33K on it with a 101 day warranty. I'm going to be installing it this week. Hopefully I'll have the car on the road again this weekend. It's been off the road for over a year now. I'm excited. I have a few parts to order but nothing major. It's going to be great to have the car back.
if you need help, hit me up
i'm always free
4433981159
Got the engine last night. I i'll have an extra intake manifold. I'll also have several other parts when completed. Let me know if there is anything that you need.
woot. awesome. when're you doing the swap? if it's today or anything and you need tools let me know. i have battery impacts and all kinda tools.
thanks!
Status
