mazdaspeed32007
- Mazdaspeed3
i just found an msd ignition universal boost timing master #5462 on sale at another web site for 80 bucks. sale prices go for like 150 and msd sells it for like 230. is this even worth the 80 bucks on this car? heres the description....not sure if its applicable or not...
"The Universal Boost Timing Master allows you to adjust the ignition timing in relation to the boost pressure plus it has a built-in inductive ignition. You can adjust the dash mounted control knob to retard the timing 1 - 3 per pound of boost, up to 15 . The increased spark output of the BTM helps burn the fuel mixture more efficiently resulting in more power - a definite advantage when boost pressure is increasing. The Universal BTM is designed to work with most single coil factory or aftermarket ignition amplifiers and points type distributors."
whuddya think?
whuddya think?
