Speed3Rookie
Guys, if you are gonna mod your 3 get the internals or pump for insurance. Either of these are cheaper than the cost of an engine. Why chance it?
really? I haven't noticed any issues with my car yet. I figured my mild mods are not a big deal. Dashhawk logs haven't shown a lack of fuel yet.
I have intake, catted dp, and ap beta. Future mods are FMIC. I'll be done with it then as far as power goes.
So as some of you may have read I had my engine replaced at 30K miles due to low compression in the #3 cylinder. I have occasionally had fuel cut symptoms, and what I swear was detonation sounds both before and after the engine replacement. Since mine is an early 07 model, I was concerned that the TSB concerning the weak high pressure fuel pump might apply to me, and that this might have caused my compression problem. I am still concerned about it because they replaced the engine, but not the fuel pump. If this could have caused the problem, then I'm at risk of destroying another engine. What do you guys think - should I press harder to get the fuel pump replaced if I verify that it's one of the weak ones built before March 26, 2007? Or should I not be concerned about it?
Are there any other advantages to the CP-E pump as opposed to the PG kit besides easiness of the install?
the most obvious advantage is if you order it, you'll get it in a respectable time frame.
but, as far as technical differences, yes, there are many.
that is one reason why it's so much money. is it overbuilt? probably! but it's certainly the best pump available.
i suggest you email cp-e about details.
we have pumps and pump internals sitting on the shelf right now. i'm not going to squat on orders, so i'd say i can commit to a 'respectable' time frame.
oh, the only reason i said that is because i've seen people on another mazdaspeedforum complaining about unreasonable wait times, that's all. no offense ; )
if i happen to see that type of thing pop up, like sanch's thread on the other forum, i'll let them know you guys are stocked.
So the only options right now are fully build CP-E pump or the PG internals kit, right?
The install of the internals looks pretty straight forward, but there's no piece of mind in form of the lifetime warranty, right?
And what are the chances something might go wrong and what could go wrong during the install of the internals?
I have the pg internals...you'll love it.Just ordered the internals. Thank you, Ken.
