Kooldino said:you watch your EGT and I'll watch my wideband.
If something goes awry, and i go hella lean, my WB02 will tell my instantly.
By the time your EGT reacts to the lean condition, your motor could be gone.
Hows that? At least My EGT is fast. Of course the A/F is faster, but that has nothing to do with a motor gone.
If I go lean, the A/F will show instantly, EGT will show later but HELLOOO, detonation will not be present until the leaning problem raise cylinder temps.
Remember, when you run a specific A/F, the EGT will remain in the same place...if it goes 50C more, then its running lean and I will know instantly...plus 50C more is not dangerous but you can setup an alarm there.
