Mp5t
Status
Not open for further replies.
The shot I've been waiting for. That's gorgeous. I assume the braile(forgive me if I'm wrong) battery didn't have what it took. I also assume the pain in accessing the battery to replace it made you change it's location. Love it's new location, fairly easy to access, yet still ninja
There are Two PC680 for a total of 1000 CCA VS 360 CCA for the Braille.
The Braille is three years old and too hard to find near me
I will remove one of them for when I require lightnes. The seat will go out too... leaving one PC680 in a low center of gravity in the middle of the car.
The two are wired in Paralell.
The ****** runs.
Regular Leaks being fixed. Clutch being bled better.
Wanted to point out that the initial cranking was insanely difficult, but after no more than 5 minutes of running, it spins freely.
I'm really liking having more battery, especially with all the high load devices like Water Pump and Cooling fans.
Friday, I will verify the brakes, clutch and all fittings for leaks, then go for a short drive of 5 Km. Come back and check, then go for a 40 Km Drive.
Change out the oil filter, Run 100 Km. Change the oil...
That line to the Intake pipe prior to the throttle body does what?
Idle Adjuster Inlet, The outlet is on the top of the 505 in the middle.
No
I I don't want to throw out my engine just yet, plus the transmission and turbo are new as well so I would break everything at once and have no car...
Wasn't interested in a Braille? Not that I really know batteries, it was just my impression that they were the best.
Status
