Mp3 wheel clucks
Jake_isr
Mazda Protege MP3 Blue Mica
I get clunks whenever I drive over anything, a dip or bump. Is this the notorious wheel clunk or do I just have bad struts?
I also get a quick cckk sound, kind of like grinding sometimes when the front driver side wheel hits a bump.
Is the "clunk" sound coming from the rear? If so, and if you don't already have it, then buy the AXR clunk fix. Should fix that problem pretty easily.
As for your 2nd concern, does it only happen when you hit bumps?
The clunk is front and rear at different times, and the 2nd problem is only sometimes, but when the driver front hits a bump.
I had a bad clunk in the rear. When I looked under my car I noticed that my endlink mount on the strut had broke. My endlink was resting on the sway bar.
Time for some new struts.
