yuphukster00 said:both![]()
Question for you. Do you have the EECV or Jspec OBDI. Either way yes. The difference would just be the harness which I can configure for you. The ZE is not a problem to scale for larger static compression. It will just require a custom tune like any other car.upsman said:Here is a question for you that hasn't been asked yet.
Do you know anything about the JDM FS-ZE engine? If so will your system work with it? I have an intake, header, exhaust, and the FS-ZE engine (higher compression) 10:5:1 in my car.
Thanks
He can make anything fit. I have an email I was getting ready for you. I will send it to you this afternoonmidnightracr said:Can a T3/T4 Garret turbo fit on the Wagner kit? If so I'll just wait until I can afford that and the AEM
I would go withat least 550cc.StuttersC said:Cool, thanks Nick. What size injectors do you think people should go with, if not the 440cc's?
I've been awake for too long now and I'm not sure if I make sense about this stuff anymore.
I understand that you can't say why. And thank you for saying that you can't say why instead of blowing smoke up my ass.
This is correct. I stated 300 WHP because of the additional enrichment you would receive with the boost compensation on the FPR. 550cc are the best way to go for the protege in my opinion.igdrasil said:I thought 440 would be good for ~280whp using the RC engineering chart w/ 80% duty cycle and stock fuel pressure ~43psi.
I was thinking on 550 for me and forged internals.
lolSpooled said:My pants are getting tight...
perfworks said:This is correct. I stated 300 WHP because of the additional enrichment you would receive with the boost compensation on the FPR. 550cc are the best way to go for the protege in my opinion.
EECV is the stock name of the stock Ford ECU found in the Protege 2.0l.upsman said:Question for you. Do you have the EECV or Jspec OBDI.
What is an EECV?
Im actually running the 2000 ES 1.8L ECU (OBDII) No CEL. Also if I can get the actual air/fuel and timing from the Sport 20 FS-ZE, would that be something that you would be able to program into my application?
perfworks said:I have been working with AEM on many of the Data stream issues.
Hopefully it will be resolved soon for all the Ford EECV ECUs.
From what I understand they are close to compiling all the necessary information needed to finish the PnP for the later EECV mustangs.
It is a fantastic unit and there is alot more to come from this company.
AS far as recognizing problems, It is mainly in the EECV. The way we have configured the unit to plug in, It will perform without a hitch.
Hit me up sometime. I may have some interesting info for you as well you for me.
Who are you working with over at AEM?
turboperformanceworks@yahoo.com
NO we are not using the 1010. We are getting a custom unitMAMotorsports said:Nick,
We aren't really working with anyone over at AEM.We talked with them and all the R&D is predy much up to us(I'm sure they told you the same thing).We do get help on a few issues, but nothing to endepth.
Are you using a 10/10 box?Have you found a source for the connectors so you can make it full PnP?
Yes, they are getting ready to release the 96-98 Mustang box.They have not completely figured out the data stream issues and are not going to release a box for the cars that have this issue(dash running off ECU) for atleast 3-6 more months.
Actually that is a very good question.ViksMSP said:Ok Nick,
So lets say i buy the parallel unit for my MSP and eventually i'll want to trade my car in for like a Mazda 3, can i just have the unit re-programmed and re-pinned for that car. Or would I only be able to do that with a full stand-alone.
Thanks.
Vik.
perfworks said:NO we are not using the 1010. We are getting a custom unit
The 1010 was originally designed for the Acura. BUT many use it as a universal. It works well, But we needed upgraded software and hardware
As far as the connectors go were are making them ourselves for the EECV harness.
Yes I believe you are right the later mustangs will have an EMS after about 6 months. They should have the issues resolved by then.
We are also working on producing a beta box for the Focus. Are you working with them yet?
I am really looking foward to doing some work on the late model drive by wire cars out this comming year.
What other projects do you work with?
Nick
