Mount for the cubby hole?
shadowfiber
2013 Mazda CX-5 Touring + Tech Pkg
I am looking for a mount of some kind, preferrably for a phone or other similar device that would be mounted to the side of the cubby hole below the climate control. This intrigues me the most as I am now using more and more apps on my phone whilst in the car.
Perfect idea would be a clip of some kind that allows the mount to go a bit above the stick area.
Does anyone have links to mounts that they can recommend for cubby/side use?
Thanks!
This is what I use
I too would like a mount like your talking about. If you find something post here for the rest of us.
I got one of these for <$10 a while ago. http://www.ebay.com/itm/Windshield-...8191?pt=US_Mounts_Holders&hash=item5404c8724f It's a clamp so youc an hold all kind of things with it. There is also a version made to clip into a vent. Maybe you can get one of these to work in the cubby hole. I have mine on the plastic next to the UI; the cup is small enough to fit. I usually only use this when I am using Torque Pro.
Chris,
I think that's not a bad idea, i wouldn't do the vent stuff, but using the mound on the black trim wouldn't be a horrible idea; does the mount damage it at all when you take it off? Is it pretty sturdy? I think my preference would still to have it lower, or near the cubby but this isn't a bad idea at all.
I was looking for something in the same spot, but then my Note3 would not fit there.
I ended up using the rear cup holder with one of these:
https://www.amazon.com (commissions earned)
I also installed a wireless charger in it and it's plugged in into the power outlet in the arm rest.
Wireless charger, that I'm using is the 3 coil type.
Everything is glued in position, so I will never have to adjust, just push in the phone.
It's not in front of me, but I don't really need it, I'm not using it while driving.
Soon, I will have a nav unit installed anyway.
Chris,
No, it wont damage it. The suction cup has a lever on it that you use to secure it, and to loosen it. This way you don't have to yank at it to remove it.
Thanks!
I have something like this (mine's a different brand, though. Don't remember where I got it):
It mounts in your charging (lighter) socket in the cubby, and the "neck" is stiff and bendable so you can angle it however you want.
