808808 said:OK so I just found out that my rear mount is torn half way through. I DO NOT want a harsh vibrating car. Could I JUST do inserts for now on the rear mount?
I hat to replace the whole thing if I can get by with inserts for awhile.
MSP21 said:The hardest mount to change on this car is the rear. You might as well just change it with a real mount and be done.
808808 said:I am soooo tired of my bucking, flopping motor. Who has had good luck with mount inserts??? I was gonna do the front only first (easiest) and see how it felt before considering the others.......advice??!!!
No vibration & cheap is not possible so far but No vibration you have it from SU and they are almost the same durability as the stock one but they come filled up unlike the stock ones.
The good thing is that SU makes all four mm .
Other than that the second in the list comes sls front mount, the bad thing is sls makes only the front and side mm.
The way I would go is sls in front and SU rear mm and that's the best imo.
Let me know how it turns out for you .
