motor build?
Whos car is this??? AMAZING!
You do not need an igniter to run the LS1 Coils
They are OEM LS1 coils, but Haltech re-sells them so that you can "One Stop Shop"
I ended up getting the AEM twinfire
You need EMS installed to operate either of these systems.
Please get the PS1000 over the SP500
The 1000 will run an idle motor and has 32x32 mapping plus many more inputs that can be used for stuff like oil pressure and fuel pressure
Ya i was planning on going with the 1000. What do you mean by 1stop shop? So you feel that the aem ones are better?
Bump just got new oil pressure and oil temp gauges.should be getting my 505 zoom manifold soon and will be ordering my ems this week along with the wiring service and patch harness
New doors installed gonna get them all retinted soon and just bought paint to redo the front bumper.
As a minimum you will need: Coolant temp sensor, Air Temp Sensor, Short or Long Patch, PS1000, Idle Motor Kit, a Haltech WBO2 Dual or Single Kit.
I will help you locate: Oil Pressure Sensor, Fuel Pressure Sensor,
The LS1 Coils are very good but they require some extra work.
1st A Plate needs to be built, I have a template that I can scan and post up.
2nd You will nee to get some wires that are compatible with the LS1 Coils. (You should read my Photo Journal in www.mp5t.com in regards to the LS1 Coils)
The AEM ignition system is easier to install but much more expensive.
Ok so would i order the coolant temp sensor right from haltech and same with the fuel pressure sensor? What kinda price difference u think for the aem system vs the ls1 coils?
