More fuel pump relay fun!
Quite possible, as the part of the wire's connector that clips to the metal stand is long gone, so it's ziptied in place but was loose for who knows how long before I got this junk car....
If by "metal strand" you mean the shielding on the crank sensor wiring, then it needs to be grounded.
The signal from the crank sensor can get lost if the shielding isn't connected.
The crank sensor signal is very small.
I'm kinda stumped.??
There is no list of conditions showing when the ECU shuts down the car and kills the spark.
The only thing I can think of is that your ECU is fried.
What about swapping your ECU from the other car.
It's quite easy to swap out.
There has been a few guys that have their ECU's go bad.
The fact that you blew the engine fuse could mean that the ECU got a surge of power that killed it.
That would also explain why it was running then died all of a sudden and hasn't tried to start since.
ECU swapped with known good ECU from 2002 parts car. No start.
Like everything else on this car, someone has already been there - bits of electrical tape sticking out of ECU's wiring harness is a clear indication of shoddy repairs of unknown nature. Several wires have been taped up in there.
Maybe inspect all the taped connections.
If the wires were just twisted together and taped, the connection can go bad.
Vinyl tape leaves sticky goo on the wires over time.
Took a chunk of my tax return and had the Blue Lemon towed (with a freshly charged battery) to a local mechanic I know and trust as being a strictly honest fellow, and who relishes electrical challenges. Gave him the full story and let him have a crack at it.
The next day, after going through multiple 10 amp engine fuses (apparently they would only blow as he turned the key off after cranking?) and getting some really oddly low RPM readings he found the Root Cause:
The harmonic balancer/toothed crank position sensor trigger wheel/crank pulley unit was disintegrated. The toothed wheel that the crank position sensor reads is bonded into place with rubber, and this rubber was rotted out with heat and age.
The oddly low RPM readings were the toothed wheel hanging loose and spinning only partially with the crankshaft. Sometimes it would hang up on the destroyed plastic of the lower timing belt cover and not spin at all - and with no crank timing input from the sensor, the ECM would not send spark.
One brand-new balancer unit later, car starts and runs fine. It doesn't even blow the 10amp engine fuse any more.
Now I have a spare car, as my new daily is an amazeballs clean low-mileage B16 Sentra SER Spec-V with 200hp and a 6-speed manual. I will continue to swap good parts onto the Blue Lemon from my parts car (especially interior) and eventually plasti-dip it before my 13 year old son needs a car. I also plan a full timing belt job with new covers, LOL.
Lesson learned: crank but no spark: check the crank trigger wheel for wiggle.
Awesome !!
We put a lot of effort trying to figuring it out.
I guess we were barking up the wrong tree. lol
I thought the toothed ring was connected to the inner hub and wouldn't slip.
I guess it's just glued on like the pulley rings.
It's gonna bug me as to why it was blowing fuses and has now stopped.
That sounds too magical for me. lol
The toothed ring to pulley hub connection appears to be a co-molded rubber bond. I'm going to take pictures of the new unit when I take it off to do timing belt at some theoretical point in the future when I get my parts car's stripped carcass out of my junk-filled garage.
The fuse blowing magically clearing up bugs my mechanic too. He went through 3 fuses. He gave me the wiring diagram printouts (a kindred soul, Pcb!) showing how the coils run through that fuse. Me no understand such electro-wizardry.
Just an FYI.
Apparently the aftermarket under drive pulleys aren't made with any rubber (they're solid metal) so the toothed ring is probably more rigidly mounted.
Your mechanic sounds like somebody I'd like to hang out with and talk shop.
This is bugging me too.
If the ECU shuts down the engine because there is no crank signal, then it should throw a P0335 code to let us know why.
Hey guys know it’s been a while but alas the gooses have grabbed hold of my vehicle too. I am having the same problem with my fuel pump relay not going clicky when I turn the key to the on position. However my car can start and run fine so I’m assuming it clicks after the ignition process is started.
I read what you guys said about the violet wire that connects to the pcm being a switch ground. When I grounded that wire manually and have the key in the on position my relay switched. So I know that for some reason my pcm is not telling the switch to ground.
I read in here, that it might be about the w/g wire coming out of the fb-3 harness but I have B+ coming out of that one.
Thinking about it now maybe the w/g wire has a short and isn’t sending enough voltage to the pcm to let it know to switch not exactly sure but hope you guys see this cause you’re wizards and warriors that can help me!
