1st MP3 in NH had this idea a while back and I thought about it myself. What if we monitored the knock sensor so that way we could tell if we were pinging or not with a light or something. Here is some info:
The knock sensor only sends data to the ECU when the following are met:
-Engine load is above 50%
-Coolent Temp is above 60C (140F)
-Engine speed is within 1500-5000 RPM
Also, when the above conditions are met, the knock sensor constantly sends a signal to the ECU. If no signal is sent for a 5 sec period the ECU throws a CEL.
Knock sensor pins are 57 (+) and 59 (-) on the ECU. With the ignition switched on, voltage on both those pins should be below 1.0V. I have not been able to find out what the voltage range is, so I assume anyhting above 1.0V is considered knock.
My idea was to make it so that when the knock sensor sends a certain voltage a light comes on, that way we could know when the engine is sensing knock.
What do you guys think?
