I noticed the car has been idling weird ever since the temperatures have fallen here in the Bay Area, they have barely gone below freezing if at All. Today I'm puttering around town and the rough idle gets more and more aggressive, then finally every time I would accelerate the whole car would judder about. I connected the obd2 connector and got 2/3 codes, P0304, P0660/ had the code pending for a little. I check to make sure all the coil packs are properly connected, I was thinking it wouldn't be the spark plugs seeing as how I replaced them 12k miles ago. I inspected the spark plug on cylinder 4, to see that the whole bottom is completely black, I knew the car ran rich and all but I was unaware it would get that bad, I replaced it with the same size plug. I check the spark plug on cylinder one, its meh, so I changed it all in the end the other two plugs as well. I clear the codes, the car starts up fine, then bam starts juddering again. I check the codes again, this time it's just the misfire code.I don't know what I need to go for next, I'm hoping I don't have to do the fuel injectors, because it's going to be hell otherwise.
