Hotel Accomodations:
For those that are coming in from out of town, a block of rooms has been reserved near the location of the event.
Quality Inn and Suites
4345 Southport Crossing Way
Indianapolis, IN 46237
(317)859-8888
Group Name:
MAZDAFEST GROUP (mention this group name when calling to reserve a room)
Map location of Hotel
Map with directions from Hotel to event
A total of
15 rooms have been blocked off for this event for Friday night (4/17) and Saturday night (4/18):
-10 of the rooms are a single which will run
$63 per night with our discount.
-The 5 remaining rooms will be doubles which will run at
$69 per night.
This is a Pet friendly hotel:
-2 pet maximum (1 dog limit)
-50 lbs max limit per animal
-$10 additional per night
There is also an indoor pool and hot tub available as well as a deluxe continental breakfast.
You will have until
April 1st to reserve one of the rooms in this block. If you wait until after April 1st, you can still obtain the same rate if rooms are available in the hotel, but there is no way of knowing if you will be in the same block as the others so reserve early!
If you decide to cancel your reservation you will need to call them no later than 1 day before the event (in this case it would be no later than 4/15) or you will get charged for the full stay!
