Mfactory LSD help....
odie84
2003 mazdaspeed protege
Is there a how to on the forums for this as I just ordered my setup and am looking for it to be in my hands in a week. Any and all help would be amazing and I know some of you will tell me to use search and I have. I dont know if I am just searching the wrong thing or not....
Did it include ARP bolts for the ring gear? If your final drive/ring gear on the stock diff is not damaged you must drill out all the factory rivets and replace them with the ARP hardware and bolt the stock ring gear to the MFactory. Then you need 2 new bearings for either side of the diff that must be pressed on. Otherwise it is just dropping the trans and splitting the case, the diff drops right in.
Im more or less looking to find the torque specs on everything. Thats the help I need sorry should have been more specific
