MazdaSpeed Parts Catalog
  • Thread starter Thread starter 4001
  • Start date Start date
you can't copy and paste from a pdf...thats why people put stuff in pdf format.
It looks ok but nothing good for the 3's except struts, sways, springs, coilovers.
When is mazda going to make a sport catback for the 3S like they did the 6??
Yes you can. In the toolbar, there's a capital "T" that may or may not say "Select Text" next to it. Click on that and it will change the little hand into a text cursor.
For instance, this is from that linked pdf:
At Mazda, performance is more than our heritage. It s our
DNA. Since 1960, Mazda has been pushing the performance
envelope in the world s most famous and rigorous auto
racing events. From our legendary victory at Le Mans to our most
recent sponsorship of the demanding Mazda Raceway Laguna Seca,
Mazda has driven the world of motor sports to its max.
Now here s your chance to maximize your Mazda, with MAZDASPEED
Performance Accessories.
(smash)
 Mazdaspeed Rear Camber Link
Rear Camber Link is recommended for all Mazdaspeed
suspension kits for the MAZDA3. Brings rear camber into
correct range.
Rear Camber Link GRMS-8M-L07
Sweeeet... this is what I'm talking about! I wonder how outrageously expensive they are.
Mazdaspeed Coil Over Suspension
Ride height adjustable system (up to 2.0in reduction), also with adjustable damping characteristics, all in a <O:p</O:psystem tuned to provide the vehicle with race technology <O:p</O:pand improved appearance. Upper mounts not included.
<O:p</O:pCoil Over Suspension RAMS-8M-L05<O:p</O:p
<O:p
Mazdaspeed Light Weight Flywheel
Light Weight Flywheel improves engine response <O:p</O:pthrough reduction in rotational mass.<O:p</O:p
Light Weight Flywheel RAMS-8M-L03<O:p></O:p>
<O:p
Mazdaspeed Sport Shifter<O:p</O:p
Manual Transmission - Reduced throw for improved <O:p</O:pfeel and shift accuracy.<O:p</O:p
Sport Shifter GRMS-8M-L11<O:p</O:p
<O:p
Mazdaspeed Sport Clutch<O:p</O:p
The Sport Clutch is designed to increase clamp load <O:p</O:pand torque capacity. Clamp load is increased and torque <O:p</O:pcapacity is increased over the OE clutch.<O:p</O:p
Sport Clutch RAMS-8M-L01<O:p</O:p
<O:p
<O:p
Mazdaspeed Sport Dampers<O:p</O:p
The Sport Dampers are designed to provide more precise steering and road feel.<O:p</O:p
Front Right QBKA-34-700<O:p</O:p
Front Left QBKA-34-900<O:p</O:p
Rear - 2 required per vehicle QBKA-28-700<O:p</O:p
Mazdaspeed Rear Camber Link<O:p</O:p
Rear Camber Link is recommended for all Mazdaspeed suspension kits for the MAZDA3. Brings rear camber into correct range.<O:p</O:p
Rear Camber Link GRMS-8M-L07<O:p</O:p
<O:p
Mazdaspeed Sport Spring<O:p</O:p
The Sport Springs reduce the ride height approximately 1.25in. Reduces body roll and improves appearance.<O:p</O:p
Sport Spring (set of 4) GRMS-8M-L05<O:p</O:p
<O:p
Mazdaspeed Stabilizer Bar Kit<O:p</O:p
Stabilizer Bar Kit provides increased steering response and reduced body roll.
Stabilizer Bar Kit GRMS-8M-L06
<O:p</O:p
Mazdaspeed Mirror Cover<O:p</O:p
Carbon Fiber appearance with the Mazdaspeed logo. Mirror Cover
QBKA-V1-450 -20<O:p</O:p
<O:p
Mazdaspeed License Plate Frame<O:p</O:p
Stainless Steel License Plate Frame with Carbon Fiber appearance. Includes the Mazdaspeed logo.<O:p</O:p
License Plate Frame BLMS-8M-C04<O:p</O:p
<O:p
Mazdaspeed Rear Under Skirt<O:p</O:p
Add-on piece to the Rear Bumper. Provides an aero and unified look to the vehicle. FRP unpainted.<O:p</O:p
Rear Under Skirt QBKA-51-980<O:p</O:p
<O:p
Mazdaspeed Front Bumper Face<O:p</O:p
Unique aero design with enlarged air openings. FRP unpainted. Requires Front Grille, QBKA-50-710.<O:p</O:p
Front Bumper Face QBKA-50-020<O:p</O:p
Mazdaspeed Add-On Roof Spoiler
Add-on piece to the OE Roof Spoiler. Urethane unpainted.<O:p</O:p
Add-On Roof Spoiler QBKA-51-960<O:p</O:p
<O:p
Mazdaspeed Front Grille<O:p</O:p
Enlarged air opening while maintaining the 5-point design theme. Required with the Front Bumper Face<O:p</O:p
QBKA-50-020. Urethane unpainted. Does not includeMazdaspeed ornaments.<O:p</O:p
Front Grille QBKA-50-710<O:p</O:p
<O:p
Mazdaspeed Add-On Side Skirt<O:p</O:p
Add-on piece to the OE Side Skirt. Provides a lowered and unified look to the vehicle. FRP unpainted.<O:p</O:p
Add-On Side Skirt QBKA-70-900
MAZDASPEED Blue Performance Accessories must be installed by MAZDASPEED Dealer on a US specification vehicle and be specifically approved by Mazda for the particular application. These parts are covered under the Mazda Replacement Parts and Accessories Limited <O:p</O:pWarranty and are warranted for the first 12 months /12,000 miles from the date of installation or the duration of the New Vehicle Limited <O:p</O:pWarranty, whichever is longer. Should the parts be purchased but not installed by a MAZDASPEED Dealer, they will be covered for the first <O:p</O:p12 months/12,000 miles from the date of purchase, excluding labor charges. Parts or accessories replaced/installed under warranty, are covered for the time remaining in the New Vehicle Limited Warranty.<O:p</O:p
MAZDASPEED Green Performance Accessories must be specifically approved by Mazda for their particular application.These parts are warranted for the first 12-months /12,000 miles from the date of purchase, excluding labor.
<O:p
MAZDASPEED Orange Performance Accessories are sold as is without any warranty of any kind. All implied warranties, including all <O:p</O:pwarranties of merchantability of fitness for a particular purpose, are excluded. Purchaser acknowledges that no representations have been made <O:p</O:pregarding these parts, including but not limited to any representations as to their quality of performance, and purchaser shall be responsible <O:p</O:pfor and bear all costs of repair of replacement due to any defect in or failure of these parts or any damage to other components. Purchaser <O:p</O:packnowledges that vehicles equipped with MAZDASPEED Orange Performance Accessories shall not be operated on public highways. <O:p</O:pMAZDASPEED Orange Performance Accessories are intended solely for the use on vehicles participating in race/off-road competition events. <O:p</O:pPurchaser acknowledges that all Mazda vehicle/parts/accessory warranties are voided if the vehicle is used in a competitive event. Purchaser <O:p</O:palso acknowledges that there will be no warranty coverage for any part or accessory that fails as a result of the installation of a MAZDASPEED <O:p</O:pOrange performance part. Purchaser accepts all responsibility for all vehicle modifications and all potential risks. <O:p</O:pMAZDASPEED Orange Performance Accessories have been designed and are intended for race/off-road applications only. Federal and many <O:p</O:pstate laws prohibit the removal, modification of, or rendering inoperative any part or vehicle system affecting emissions or safety.
I'm pretty sure a Mazdaspeed catback for the 3 is available through japanparts.com, but probably for an upwards of around $600+ if with the currency conversion, not to mention shipping...
Any info on ordering any of these Mazdaspeed parts VIA my dealer and not voiding my warranty?
Thanks
PRBOY3
yeah, I think I'd rather stick with the Borla exhaust thats out for them now...they are pretty cheap if I recall.
M3 exhaust
A careful reading of the websites in this thread plus the PDF files indicates there are currently no Mazdaspeed exhaust parts available. There are a number of suspension upgrades as well as a perf. clutch, but NO exhaust or intake.
Thought I'd simplify this Q and A as I have done the searching.
Thanks
PRBOY3
Did you read this
<O:p
japanparts only lists a "SPORTS SOUND MUFFLER" and it's $700. (shocked)
Oh, and I just called my local Mazdaspeed dealer and prices aren't even available yet. :rolleyes:
