Mazdaspeed 3 rear camber adjustable plates???
Hello
Went to get my alignment today and was told that right rear (psgr. side) was off and could not be adjusted to spec because the Mazdaspeed camber plates are not adjustable. Im off by a half of a degree but Im picky. I knew they were not adjustable. I started looking and found some camber rear adj for Mazdaspeed 3. Here is a list and would like to know has anyone put them on? If you did, what did you think??? Any input would be appreciated
1. Wicked Performance on ebay:
http://cgi.ebay.com/ebaymotors/WICK...ptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
2. SPC Camber Adjustable Rear Arm: available from **********. but I think it is priced each one for 109.00 EACH?? here is the link
http://www.***************/SPC_Camber_Arm_MS3_Mazda_3_p/67420.htm
Id like to get that camber right. thanks in advance
I have the spc camber links and I like them alot. they work well and are well made. theres alot of room for adjustment with them as well.
I've got the SPC's and I'm glad I put them on. I can adjust the camber now and get it exactly right. They are also much stronger pieces so it will not get knocked out of whack.
