Mazda5 hub spindle question..
rhayan911
Hi guys! I'm having a noise on my front wheel bearing sound like a ball bearing loosed on track, I'm planning to fix the noise by replacing the whole hub spindle assembly. Just want to ask if the hub spindle/knuckle from MAZDA 3 can fit the mazda5? would their be any problem in fitting? does all year model of 3 can fit on 5? I don't have time in bringing the hub to shop for pressing the bearing. hope to hear from you guys.
You can search a parts database and compare the results of the two cars OR call any Mazda Dealer parts department to confirm the part number...
Did your dirt. Looks interchangeable to me.
www.rockauto.com
2008 MAZDA 3 I 2.0L 2000cc L4 FI DOHC
: Brake/Wheel Hub : Axle Bearing and Hub Assembly Wiki Price
NATIONAL Part # 512348 Hub Assembly
Rear Wheel; Exc. ABS
$140.79
Add to Cart
SKF Part # BR930681 {#BP4K2615XC, BP4K2615XF} Wheel PIO diameter=2.6377"; Bolt hole size=.3397"; Bolt circle diameter B=3.8385"; Bolt circle diameter A=4.5275"; Hub PIO diameter=2.9133"; Flange offset=2.4842"; Flange diameter=5.5905"; Brake PIO diameter=2.8346IN
4-Wheel ABS; Rear (Only 1 Remaining)
- Stocked in outlying warehouse--shipping delayed up to 1 business day
$156.79
Add to Cart
NATIONAL Part # 512347 Hub Assembly
Rear Wheel; ABS
* Non-stock item--shipping delayed up to 2 business days
$152.79
Add to Cart
TIMKEN Part # HA590099 Ball Bearing; 4.5 in. Bolt Circle Diam; 5.590 in. Flange Diameter; 2.484 in. Flange Offset; Modified Flange Shape; 67 mm Wheel Pilot Diam
FWD; 4-Wheel ABS; Rear
* Non-stock item--shipping delayed up to 5 business days
$115.79
vs
2008 MAZDA 5 TOURING 2.3L 2260cc L4 FI DOHC
$156.79
Add to Cart
Rear Wheel
$152.79
Add to Cart
FWD; Rear
$115.79
I wouldn't dismantle the hub assembly anyways on an ABS equipped vehicle.
Anyways, it looks like you'll be fine swapping for the same model year 3.
