MAZDASPEED PROTEGE NON-TURBO PARTS LIST
Description Mazda Part Number Qty/Kit
Rear Skirt, Primer 0000-8Y-C06-00 1
Spoiler, Primer 0000-8Y-C06-00 1
Trunk Lid Torsion Bar R BNYH-52-791 1
Trunk Lid Torsion Bar L BNYH-52-792 1
Wind Split 0000-88-C07 1
Wind Split Hardware 0000-88-C23* 1
Trunk Badge 0000-88C12** 1
Engine Badge 0000-88C13** 1
Shift Pattern 0000-88-C17 1
Front Mascot 0000-8R-C10 1
Rear Mascot 0000-8R-C11 1
Protege Symbol 0000-8R-C13 1
Shift Knob 0000-88-C10 1
Floor Mats 0000-87-7701-09 1
Audio Head Unit 0000-81-C19 1
Subwoofer/Amp/Tray 0000-81-C33 1
Front Speakers 0000-81-C04A 1
Rear Speakers 0000-81-C32 1
Emissions (VECI) Label BP7H-66-036 1
Muffler 0000-8M-C09 1
Wheel Lock 0000-88-120C 1
Alarm 0000-8F-C04 1
Cargo Net 0000-88-5499-0A 1
*Part number appears to be same as Item 14 on Turbo System Parts list.
Please confirm correct numbers
**Typos? Shouldn't there be a dash between 88 and C12?
MAZDASPEED PROTEGE TURBO SYSTEM PARTS LIST
Item Number Description Mazda Part Number Qty/Kit
1 Exhaust Manifold 0000-88-C40 1
2 Stud, Exhaust Manifold-to-Turbo 0000-88-C16 4
3 Gasket, Turbine Inlet 0000-88-C17 1
4 Turbocharger 0000-88-C42 1
5 Stud, Turbine Outlet 0000-88-C18 5
6 Gasket, Turbine Outlet 0000-88-C19 1
7 Heat Shield, Turbo 0000-88-C43 1
8 Downpipe 0000-88-C45 1
9 Stud, Downpipe-to-Elbow 0000-88-C20 3
10 Clamp Set, Oil Feed Hose 0000-88-C46 1
11 Bolt, Clamp Mounting 0000-88-C47 1
12 Turbo Drain Flange Assembly 0000-88-C48 1
13 O-ring 0000-88-C22 1
14 Bolt, Oil Drain Fitting-to-Turbo 0000-88-C23 2
15 Washer 0000-88-C24 2
16 Hose, Turbo Oil Drain 0000-88-C25 1
17 Clamp, Hose to Turbo Drain Flange 0000-88-C26 1
18 Pipe, Water Feed Assembly 0000-88-C49 1
19 Bolt, Banjo 14mm x 1.5mm 0000-88-C50 1
20 Gasket, Banjo 0000-88-C27 1
21 Clamp, Hose Water Feed 0000-88-C51 1
22 Pipe, Water Return Assembly 0000-88-C52 1
23 Heat Shield, Exhaust Manifold 0000-88-C53 1
24 Water Return Elbow 0000-88-C54 1
25 Clamp, Water Return Pipe to Elbow 0000-88-C55 1
26 Duct, MAF Sensor-to-Compressor Inlet 0000-88-C56 1
27 Clamp, MAF Sensor-to-duct 0000 88 C63 1
28 Clamp, Compressor inlet-to-duct 0000 88 C84 1
29 Duct, Compressor Out-to-Intercooler Inlet 0000-88-C57 1
30 Clamp, Compout, IC in, IC out-to-duct 0000 88 C85 1
31 Duct, Intercooler Out-to-Throttlebody 0000-88-C58 1
32 Clamp, Throttlebody-to-duct 0000 88 C86 1
33 Duct. Inlet Air-to-Airbox 0000-88-C59 1
34 Insulator, Air Duct S501-13-349 1
35 Spacer, Air Duct PS05-13-321 1
36 Bolt, Air Duct 90786-0620 1
37 Bypass Valve N3A1-20-250 1
38 Hose, Bypass Valve 0000-88-C61 1
39 Hose, Bypass Valve 0000-88-C62 1
40 Clamp, Oetkier 0000-88-C63 1
41 Clamp, Spring 0000-88-C64 1
42 Clamp, Intake Hose 0000-88-C32 2
43 Clamp, TEE to ABV and WG Actuator 0000-88-C33 4
44 Check Valve, Canister Purge 0000-88-C67 1
45 Hose, CV to Intake Manifold FS7N-20-371A 1
46 Hose, CV to Solenoid ZM39-20-361 1
47 Clamp, CV Intake 0000-88-C88 2
48 Clamp, CV Solenoid 0000-88-C69 2
49 Wire Tie w/ Clip - Oil Feed Line B511-67091 1
50 Lower Radiator Hose 0000-88-C70 1
