So it started sat. Removed the IM, TB and EGR to clean the EGR and replace all the gakets in order to fix my vac leak. Did the trick, went for a drive and she died and I had to get towed home ($75). Spend the next three days trying to figure out why the car would crank but not start (no power to fuel pump or injectors and temp guage reading Hot). Hardwired the pump to make sure it was working, had a new pump relay sent to me but nothing...
So today when I got home from work, checked the O2 sensors for a short ... nothing. Pulled the IM (basically reversing the work I did sat.) then put everything back in checking absolutely everything as I went. Got it all back together, put the key in and nothing.
But then! A breakthrough...in the fuse box in the drivers foot well the 10A fuse labeled "ENGINE" was blown. Replaced it with the one next to it (which prolly wasnt the best idea because the tranny doesnt shift and I think it started to overheat a little) but the car started and I got to Advance auto not too far away. Grabbed a box of 25 10A fuses and put one in in the parking lot. Car was back to its old self minus a CEL
But then it gets bad ... about 1/4 mile past the place I got towed from last time the car dies again. So I said, no worries Ill just replace the fuse, put it in and it blew instantly, five more fuses went this way... so I had to call for a tow
$65 dollars and 2 hours later my car is back in the parking lot at my appt.
Any ideas?
